If you're not part of the solution....
Off-topic conversations and chit-chat.
9 posts Page 1 of 1
If you're not part of the solution...............
.......you're a gas or a solid!
Jimmy Carr 2006
Cheers,
Ralph
you're part of the precipitate.
http://www.toothpastefordinner.com/0109 ... lution.gif
The other cartoons on this site are well worth browsing through if you have the time.
Yes, I prefer your version
Ralph
...then you're suspended!
good one! Image
Why did the white bear dissolve in water?
'cause it was polar!!!
GCguy
I believe Jimmy Carr used to work in the petrochemical industry so he should know!!
WK
I'm Sorry I Haven't A Clue - Just A Minute - The Unbelievable Truth
What to do ...
when a lead turns into lead ?
9 posts Page 1 of 1
