Hypersil Duet Cation HPLC column
Does anyone know what kind of a phase exactly is Hypersil Duet Cation? It looks like an old column if it helps.
Cheers
A
Don't argue with an idiot... he will drag you to his level and beat you with experience!
I was able to google this by myself lol. However I am not sure this is one and the same column since it has a different name (see above) and these look like new generation columns where mine looks older.
The only way to tell for sure is to find the part number on the label or tag of your column and check with Thermo.
Users browsing this forum: Bing [Bot] and 21 guests
