influence make-up gas on detector
My detector signal has suddenly dropped with a factor of 4. Could this be caused by the lack of make-up gas (e.g. nitrogen) for the detector? The retention-times havent changed.
Hello Martinz,
yes! Did You have a FID? If yes, You need make up gas because of the flame geometry AND the gas velocity from the jet into the flame.
A good make up gas for FID is N2 or Air. The flow is instrument depending and mostly between 25 and 45 ml/min.
He is for FIDs not a good choice.
rgds
Bernd
bm
Thanks! turns out some #$%& let a valve open. lost a N2 bottle in less than a day.
Users browsing this forum: Semrush [Bot] and 8 guests
