mAu and millivolts
are mAu and millivolts units interchangeable in HPLC in case of PDA detector?
You need to check, if the detector output is 1 V per 1 AU. This may be, or may not be. Look in the manual.
I assume from the context of the question that you have a PDA connected through some interface box. Check the configurations of each.
Mark Tracy
Senior Chemist
Dionex Corp.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 9 guests
