processing a sample for HPLC
I have an hydrolysate in 6N HCl that I have to neutralize and precipitate and I don't know with what and what concentration with. Could anyone help me to find this out? I have to run it on HPLC so it has to be clean before I derivitize it for amino acids. I would like to find out how the chemistry works too could you lead me to any sights to look at to see how it works for further processing methods I may need to do? Thanks for yur Help Tracy
Since HCl is volatile, the more usual approach is to dry the sample either by freeze-drying or rotary evaporator. Then reconstitute in a compatible buffer. Then filter.
If you want to neutralize, use 6M NaOH. That is messy because it leaves a lot of NaCl that can interfere with later processing. Also, you don't want to titrate each sample if you can avoid it.
Mark Tracy
Senior Chemist
Dionex Corp.
Senior Chemist
Dionex Corp.
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
