Peak in blank
20 posts Page 2 of 2
That's fine, Marian.
So you flow 1ml/min, length 10 cm, and void time 1 min,
my estimation found you column ID is 4.2 mm, is this correct?
Have a great day,
Excel
Are you using plastic vials or glass vials?
what will happen if you continuously inject 10 times of 200ul MeOH? If the peak shrinked, your syetems (both, coincidently) were contaminated.
Good Luck,
Excel
Your problem is called solvent front. :D
Marian:
have you solved your problem?
if you did, what is the root cause?
thanks,
Excel
