TSK Gel Amide80 method
Hi!
I am trying to resolve a 10 residue peptide on a TSK gel amide 80 column ( 1mm ID) using TFA-acetonitrile solvent system. Can you please suggest an initial method?
I cannot use metal salts as i have it going to the mass spectrometer. My peptide sequence is AEDVGSNKGA.
Any suggestions will be greatly appreciated.
Thanks!
UCLA-DOE
Chemistry and Biochemistry
What are you trying to resolve it from?
I am trying to resolve a proteolytic digest of the peptide AEDVGSNKGA. I first need to see a good retention of the intact peptide on the column and then work from there. I need to quantify the reduction in peak area as this peptide undergoes proteolysis.
Roy.
UCLA-DOE
A quick look on Google for "predicted retention of peptides" found this:
http://www.springerlink.com/content/v766588734113p72/
One of the columns mentioned is an amide column under normal-phase conditions.
Mark Tracy
Senior Chemist
Dionex Corp.
Thanks Mark!
Roy.
UCLA-DOE
