Agilent 6890 Inlet Fan?
The fan that cools the injector on the 6890 started making lots of noise so I pulled it out, cleaned it, put a drop of oil on the shaft...its much better but still makes noise so I'm trying to find a direct replacement..the label is unreadable so all I can read is Sanyo model 109R08 DC 24V 1R IC2 and some of that is a guess...i can't find the exact one without the full part # as there are lots with the staring numbers..can anyone point me in the right direction or know where to get a replacement for a reasonable cost? Thanks!! EG
- tom jupille
- Site Admin
There are only about 4 choices with and 4 choices without a tachometer.
http://www.mouser.com/catalog/catalogusd/645/3012.pdf
All the same size and voltage. They are only around ten bucks apiece. If this were my problem I'd just order the one with the highest airflow.
Thanks Tom Appreciate the help! We have another 6890 I might pop that one out see if the part # is clearer before ordering
I just pulled the the other one :109R0824H4021
Going to order a couple
Thanks Tom!
Thanks Tom!
In total there are 18 users online :: 0 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 18 guests
