Source of Electropolished Tubing for HPLC Columns
Hello Everybody,
I am looking for a source of electropolished tubing for HPLC columns with standard 2.1, 3.2 and 4.6 mm ID and 7-8 mm OD. Looking for tubes which can be cut to length.
Thank you.
Vlad Orlovsky
HELIX Chromatography
www.helixchrom.com
Hi Vlad,
Are you looking for tubing with which to pack columns w/ end fittings and associated hardware?
MattM
I can consider both approaches right now. Ideally we want to machine our hardware (end fittings), so technically speaking EP tubing should be fine. I can be few feet long and we can cut and machine.
Vlad Orlovsky
www.helixchrom.com
Hi Again,
Would not IDEX:
https://www.idex-hs.com/fluidics/column ... stems.html
or Restek:
http://www.restek.com/catalog/view/675
fit some of the bill?
MattM
I don't like compression ring hardware and you can only do compression ring for 1/4 OD for 4.6 mm columns and prices are not very good :)
Vlad Orlovsky
www.helixchrom.com
Understood Vlad and thank you! I'll keep looking on this end.
MattM
In total there are 18 users online :: 0 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 18 guests
