Metformin problem
19 posts Page 2 of 2
Thanks Mattmullaney,
I also share that I used ionpairing method and talked to you 7 days ago. It is not successfull to use it, because tR Met is not tM, so, pic Vildagliptin is not appear.
So...I haven't found a new method.
Thank you very much for your enthusiasm!
Hi again,
So that I understand, metformin + the ion-pairing agent is now eluting away from the void volume, and Vildagliptin is not eluting at all?
This is horrible luck. I am sorry to hear it.
Will the next move be to HILIC, then?
MattM
Hi Mattmullaney
Thank you for your helping
Because our devices have limited, HILIC method is unabled to do.
I will read more information. so If you have any idea, I hope you will share it to me.
Best & regard!
Hi Again DIEGC40,
I'll go back to looking for methods...not sure what I'll turn up, but will try.
MattM
In total there are 27 users online :: 1 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 26 guests
