hplc method for lamivudine, zidovudine and nevirapine
can anybody tell me a method which will simultaneously determine lamivudine, zidovudine and nevirapine.
and which will be the prefered pH.
I suggest a silica HILIC column (Atlantis HILIC). Start off with a gradient from 90% acetonitrile to 50% acetonitrile. Then narrow the gradient and/or adjust the pH.
I used ammonnium acetate and MeOH in gradient.
flow rate 0.4 ml/min in UPLC.
column : Acquity BEH C18, 2.1x50mm,1.7um.
and analysis time was 4 min.
e-mail to me, I will give you more information
kasiban@hotmail.com
LZN
I have the method, why do you require this? regds/MSReddy :?:
i am working on these grugs. i got project.
In total there are 26 users online :: 1 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 25 guests
