NDMA split peak
I'm using a GC 6890 and a MS 5973 to analyze n-nitrosodimethylamine. Everything was going well until we fell 2 PT's. We have a higher concentration than expected. When I looked back at the chromatograph, I noticed that for the PT's sample only I have a small peak besides/overlapping my internal standard peak. I don't find the same problem in my standards nor my spiked sample. If I integrate the two peaks, I have the right concentration of NDMA. Even when I check the surface area, the difference is not a lot compared to the spiked sample so I had no clue if I had to integrate the two peaks or not. (Ex. spike ISTD 77936, Sample ISTD 1 peak = 71073 2 peaks= 87894..) What can cause my internal standard peak to separate only for the PT samples? I checked last year PT chromatographs and there's no separation. Thank you, Marie
What is the internal standard? Does it elute before or after the NDMA?
In total there are 19 users online :: 1 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 18 guests
