ephedrine/pseudoephedrine separation and quantification
I am looking to quantitate ephedrine/pseudoephedrine in a natural product sida cordifolia. Any ideas on the column, conditions etc. that can be used. Any suggestions will be appreciated.
I have successfully done semiquants on differentiating methamphetamine, amphetamine, pseudophedr, and ephedrine using Thin Layer Chromatography.
Jumpshooter
Thanks, but I was looking to use HPLC. Any suggestions on columns, Mobile Phases etc.?
A detailed discussion, including methods, can be found here:-
http://rivm.nl/bibliotheek/rapporten/670220001.pdf
I'm sure there are many others available via Google...
Bruce Hamilton
Thank you for pointing me in the right direction
Here's another. Just replace MS/MS with DAD. You might have a problem with interfering peaks with a DAD, but you may get some good ideas. :wink:
AOAC Ephedra Submission
