Empower - Calibration curve using old standards
Hi ,
Processing method is using old standards from previous sample set and new standards when processing and using these to create calibration curve ...
Clear calibration present in sample set ,,
why is this doing this ?
Nothing tagged as a standard in the SSM?
DR
Hi ,
SSM - Sample set method
to clarify standards labelled as 'standards' in sample set (x2)
Calibration curve has 4 points when using processing method
Looking at result ID these are from an old sample set / calibration curve
Clear calibration used
