CarboPAc PA10 regeneration??
hi
Can any one suggest me a method for regeneration of CarboPac PA10 column..??
Thanks a lot
I have just had a look on the Dionex website and found the following pdf that may be of use to you. It is a combined CarboPac Product Manual but contains lots of information about the PA10. In Section 5.2.3, there is a passage about column cleaning which is probably worth a try.
http://www1.dionex.com/en-us/webdocs/43 ... ed_V26.pdf
Hope this helps!
Steve.
In total there are 14 users online :: 0 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 14 guests
