Agilent Chemstation Rev. B.04.02 not initializing
I am trying to set up an 1100 Series HPLC for one of our labs. I have been able to connect and configure the instrument, however the software will not initialize. The software stops on the Data Analysis portion of the initialization. I have checked the CHEMSTATION.INI to see if the paths for initialization were correct, and they all seem to be. I also went through the Windows OS configuration steps provided by the Agilent Manual, and have uninstalled and reinstalled the software. Any ideas as to what could be wrong? Thanks in advance.
something to check first:
- What is the Window version ?
- Do you make sure that source code of B.04.02 you extracted from .ISO or copy from CD Rom do not get any error ?
- Do you install IO library ?
- Do you have .Net framework meet this version requirement ?
GiMiTEC | https://gimitec.com/catalog
In total there are 10 users online :: 3 registered, 0 hidden and 7 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Semrush [Bot] and 7 guests
