C18 column swich from 65% ACN to 65% MeOH
C18 column swiched directly from 65% ACN 35% H20 to 65% MeOH 35% H20. Is it Ok for the column?
Thanks!
should be fine; your pressures will be less with ACN, and most likely your analytes will elute a little sooner with ACN if the percent organic remains the same
Thanks!!
In total there are 7 users online :: 3 registered, 0 hidden and 4 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 4 guests
