Regarding the analysis of water soluble vitamins
can anyone suggest me a method to analyse all the water soluble vitamins using rp-hplc? Is it possible to estimate vitamins using phenyl column?
There you go:
https://www.sigmaaldrich.com/technical- ... n-c18.html
Information like this can be easily found via google.
Quantification is obviously possible as well if you have the respective standards of each vitamin.
I tried several methods that are available in google. but, none of the methods gave me accurate results. so i need a rapid and precise mehod for better quantification and seperation.
Users browsing this forum: Semrush [Bot] and 12 guests
