Ballasting procedure
Dumb question - to gas ballast an Edwards rough pump can I simply open the ballast valve while the MS is pumped down? Or does the pump need to be isolated from the system?
https://www.manualslib.com/manual/12280 ... =34#manual
https://www.manualslib.com/manual/12280 ... =35#manual
Found this in the manual, looks like you can switch them with the pump running.
