SIMDIS PTV operating pressure/flow ?
Hi, I am currently creating a method based of of ASTM D7169.
I am using a PTV inlet.
my column diameters are as follows length 5M internal diameter 0.55mm and a film thickness of 0.15µm. my current column flow is 20ml/min He ( constant flow)
can someone please recommend flow rate starting conditions for the PTV.
should it be higher or lower than the column flow ?
Thanks in advance.
Chemiger
99 problems and chromatography is every one !
Chemiger,
The Simdis inlets I am used to are on-column. 20 mL/min is appropriate in that scenario. By implication, you have a splitter or purge flow as well?
Best regards,
AICMM
Hi Sorry for the late reply I haven't been working on the project for a while
I do not have a splitter on this system,I do have purge flow on.
Chemiger
In total there are 15 users online :: 0 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 15 guests
