.RPT Viewing
I use turbochrom (Yes, I know its horribly outdated) to compile my report in a .RPT format from the .RAW format.
My problem is that I need to move my .RPT files from my main computer to another computer which does not have Turbochrom on it. Is there any way to view .RPT files with a program or any other means without having Turbochrom software installed?
Thanks for looking :D
It won't be the .rpt format any more, but I believe you should be able to go to your sequence, process it just to print, and select Adobe Acrobat as your printer. The resulting .pdf files are transferable to any computer.
All standard disclaimers apply. My posts are my opinions only and do not necessarily reflect the policies of my employer.
Users browsing this forum: Bing [Bot] and 5 guests
