Disregard limits and sum
Discussions about methods, troubleshooting and best practices across both pharmaceutical and biopharmaceutical analysis.
internally we have a discussion about rounding and sum of impurities.
When we have a disregard limit of 0.3%, and we have some unknown impurites of 0.25%, 0.301% and 0.7%.
Should we round our results before totalling so that 0.301 becomes 0.3 and should be disregarded?
Or is the sum 1.0%?
Best regards
Ace
I would say that if your limit of 0.3% is to one significant figure, then each result can only be to one significant figure.
Or is the sum 1.0%?
Best regards
Ace
First result what You disregard is 0.24.
0.25, 0.301 not UDL.
Result of sum regards from Your requirements. 1 per cent or 1.0 per cent. Respectively it's 2 or 1.6 per cent.
You need to document whether your limits are inclusive or exclusive. If 0.3 is the limit, is a peak of 0.3 excluded (just) or included (just)?
The motivation for excluding tiny peaks is a historical feeling, dating back to the days of wobbly baselines, that it's wrong to reject something based on the sum of a large number of very tiny bumps, which might just be noise. This is a good justification, but it was never intended as a justification for ignoring definite contaminants.
If your motivation for worrying about the extra 0.3% is that 1% summed contaminants is the threshold at which disaster strikes, then the answer to the rounding question is this:
If you have only three, well-defined contaminant peaks that sum to 1.25% of the total, are you excited about the idea of explaining to a regulatory body why 1.25% < 1.0% based on what might easily look like creative use of rounding?
In total there are 0 users online :: 0 registered, 0 hidden and 0 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 0 guests
