How many points needed for the smooth?
How to decide how many points needed for the smooth process? I run the LC/MS/MS experiments to quantitate analytes. In Masslynx, it seems to select the points number equal to half peak width. Is it the best choice for others too?
It depends on the smoothing algorithm. For instance, Gauss and Box-car smoothing broaden peaks horrendously, and can ruin a well-shaped peak; use them with only a very few points. If you have 15 points across a peak, I wouldn't dare go beyond 3 (or 5 in an emergency) with these.
Savitsky-Golay smoothing, on the other hand, is an extremely clever way to fit a polynomial through nearby points (with computational costs similar to Gauss and Box-car), and make the new point a point from this polynomial. It can match the curve at the start of a chromatographic peak without messing it up, so it can be used with quite substantial numbers of points, without any damage to peak-shape. For the 15-point peak-width, depending on the polynomial order that your algorithm uses, you may be able to use 11-15 point smoothing without trouble.
Frankly, I don't know why anyone offers Gaussian or boxcar smoothing, except for backward-compatibility to old methods, since both are thoroughly brutish. Gaussian is also open to a dangerous misuse: If you have a scan speed so slow that something runs as a peak only 1-2 points wide, a Gaussian smooth can make it into a beautiful Gaussian peak.
