Grob Test Mixture reproducibility
Hi all,
I met this problem when I tested the reproducibility using grob test mixture (three injections, diluted in DCM). The system I use is a GCxGC-ToFMS.
Some compound like Decane, undecane, Methyl caprate,.. have ~4% RSD
However, octanol, nonanal, 2,6-Xylidine have ~25% RSD
May I ask what could be the problem?
thank you!
We will need to know the column phases and sizes, oven temperature program, inlet parameters and any other information you can give to know where the problem may be. Many things can affect reproducibility.
Do you have the 2,6-xylidene and nonanal in the same solution?
Users browsing this forum: Semrush [Bot] and 13 guests
