Ballast on rough pump in LC/MS
Hi all,
Why đo I have to open the ballast on rough pump in LC/MS, while not in GC/MS?
Thanks.
In a GC, the vacuum pumps are removing a fairly small trickle of gas. In an LC-MS, they are removing a larger volume of vapour from a much less volatile liquid (the hplc solvent). The vacuum pumps therefore tend to accumulate solvent in their oil in the LC system, which isn't a problem in the GC system. The ballasting allows them to get rid of accumulated solvent, and keeps the oil cleaner.
Whatever Imh has told you is true
In total there are 32 users online :: 1 registered, 0 hidden and 31 guests (based on users active over the past 5 minutes)
Users browsing this forum: Amazon [Bot] and 31 guests
