PTV inlet
Can someone suggest to me the best PTV inlet on the market? Agilent? Thermo? Gerstel? other?
If you are using the Agilent 7890 or above I would look into the Agilent MMI (Multi Mode Inlet) It can do normal split or splitless plus solvent evaporation large volume applications and uses the same standard liner as other Agilent inlets.
For non Agilent instruments I have also used the Gerstel with good results.
thank you so much! :)
Users browsing this forum: Google [Bot] and 8 guests
