Empower 3 reports
So I am new to chromatography. I am working with a Waters legacy system using the first version of Empower 3. I have a data set (sample set of standard x5 and some assays and some CU samples with a blank every 5 injections.) I can do a report to get any single injection in a report with an extracted chromatogram. What i need is a report with all of the injections in the same PDF. Anyone know how to merge the PDF's or make Empower software generate a report with more than one injection per PDF? Any help would be wonderful.
"Summary by all"
Among report method properties - find it (right-click the white space outside any table or graphic in your report method), check it. It will help.
DR
Thank you! That worked a treat.
