Shimadzu GCMS autotune failing 502 intensity
I have a GCMS=QP2020NX from shimadzu that started failing a 502 check after changing the column. I cleaned the source, changed the filaments, cleaned the lens stack, cleaned the rods. Still nothing.
Any ideas?
Any ideas?
Revert older column
Check the position of the column at the ion source. It is sensitive to the geometry.
In total there are 32 users online :: 0 registered, 0 hidden and 32 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 32 guests
