Errors occured during GCMS Analysis
Can anyone help me resolve these issues?
I have encountered the following errors during GCMS analysis:
1) CAR1 AFC leaks.
2) CAR1 primary pressure is out of range
3) Carrier gas does not flow sufficiently
4) Vacuum Auto Startup sequence has stopped.
Need to know which model and vendor the GCMS is to know what the errors mean. Each will have its own error codes.
1) CAR1 AFC leaks.
You have the answer already - number 1) - there is a leak. The rest is a consequence of that.
Fix it.
Users browsing this forum: Google [Bot] and 3 guests
