CP-4900 Micro GC Software
I have a CP-4900 Varian Micro-GC and want to do some gas analysis. Unfortunately, the software has some critical problems and will not load methods/sample lists without crashing.
Does anybody know where I can download new software compatible with the CP-4900 that provides all the functions required to complete basic gas analysis (e.g. method/sample lists/data processing/results etc.).
Many thanks
Marc
Marc,
the CP-4900 is supported by OpenLab EZChrom and can be obtained from your local Agilent office.
Freek Varossieau
OpenLab CDS 2 specialist
BeyondOpenLab
beyondopenlab@gmail.com
+5977114721
Many thanks
Marc
Hello Marc
send email, i want more details, I think that i can help you.
Thanks for the replies. I spoke to Agilent and they were able to send me the installation files for Galaxie, so looks like the problem is solved now. Will let you know, if not.
Marc
I have a similar issue with my CP-4900. I followed the instructions for the installation of Galaxie v1.9 and the GC controller. I am able to setup and connect the system via the Configuration Manager. The CP-4900 communicates and sends/receives the settings. Note that the two channels/columns are colored red, everything seems ok and the CP-4900 is Ready. I do not if this ok and indicates an issue.
When I open the Galaxie software the system does not appear at all, for any user. I have only one system so I do know if it is a problem with the CP-4900 or the Galaxie.
Does anyone have any idea about what can be the issue? I am completely newbie on the matter.
Forgot to mention, that I also tried with the local distributors (I am based in Qatar) with no luck. They stopped trying way earlier than I reaced.
Hi all
I have the same issue trying to find the installation software. When I arrived at my lab the media was already lost. I contacted my local agilent contact with no luck, they don't support anymore. Can you please help me find the drivers and the software for the CP-4900?
my e-maill is brunolemos@ipt.br
thanks
