We have been seeing contamination in some 8270 extracts, specifically for 1,4-dioxane SIM analysis; present mostly in soils as opposed to waters.
Contamination appears to be a combination of 2,5-dimethylfuran and 2,4-dimethylfuran.
Tests indicate significant levels of these two compounds when we test using acetone only. Contamination is very low when using only methylene chloride.
We are using Optima grade acetone. Could this contamination really be coming right out of the bottles? Curious if anyone has seen this before.
Thank you.
Christian
