Comparison of Z-HILIC Columns
1. InfinityLab Poroshell 120 HILIC-Z, 2.1 x 150 mm, 2.7 µm
2. Atlantis Premier BEH Z-HILIC VanGuard FIT Column, 2.5 µm, 2.1 mm x 150 mm
Does anyone have experience using either of these columns for general metabolomics applications? I am having trouble deciding which one to get. One seems to offer higher chemical stability at extreme pH values while the other can tolerate significant more backpressure. If anyone has used both, your input would be greatly appreciated!
Thanks in advance!
We have been using an Acquity Premier Z-HILIC 2.1x100, 1.7um for quite a while now. I cannot compare with the Poroshell but compared to the older BEH Amide or HILIC, we observed that retention times were much more stable within and inter-batches. Also, it somehow provided better peak shapes for some difficult compounds (e.g. phosphated) but in our applications I would say the effect was rather marginal.
In total there are 23 users online :: 0 registered, 0 hidden and 23 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 23 guests
