In search of software/hardware to update older system
We have some older HPLC equipment in our laboratory (we are an academic research group). One system has the following components:
SSI 222C pump
SSI 232C gradient
Shimadzu RF-10AXL fluorescence detector
The other system has the following components:
Shimadzu RF-551 spectrofluorometric detector
Shimadzu SPD-5AV UV-Visibile detector
HP Series 1050 pump
We are looking for a system that can accomodate this instrumentation for use with Windows XP, Vista, or MacOS X (Windows preferred), along the lines of eDaq PowerChrom system (software + box to drive instrument): http://www.edaq.com/powerchromsystems.html. Are there similar systems available? Which is the best? The most cost effective?
Recommendations are appreciated.
Aaron
Most any modern system will be able to take a 1V analog signal via A/D converter, so as long as you have the needed controllers, you should be able to use what you have.
DR
Thanks. Does anyone have any recommendations for A/D converters, in particular, one that has a USB connection?
Aaron
You can consider our Clarity software with U-PAD2 A/D converter (2 channel, USB connection). Details and distributors can be found on our web pages www.dataapex.com.
Software company representative should pay more attention on details :)
correct link is http://www.dataapex.com
Thank you for correction, dblux_
