wavelength accuracy
Hi to all,
I would like to know
what concentration of standard solution should be used to perform the wavelength accuracy test with aqueous caffeine solution for HPLC-UV-Vis detector calibration and is there any guideline to use caffeine as standard.
Thanks in advance
Nageshwar
I would favour the use of a STD which does not produce an absorbance in excess of 1000 mAU (1 AU) at the theoretical caffeine absorbance maximum.
We use a 25 µL injection of a 50 µg/mL STD solution.
you should check if your detector has a mercury lamp.
this lamp has a set of very specific WL and it is used these days in many detector for WL accuracy of the optics
The detector is built with duterium lamp.
Nageshwar
Users browsing this forum: Semrush [Bot] and 15 guests
