HPLC Method Validation- Accuracy
19 posts Page 2 of 2
Thank you.
Does that mean it is OK to use the medium only for recovery measurements?
In my view, yes.
mdyo,
Do you want to validate the chromatographic method or
Do you want to measure some results?
If you want to validate, that would be done best with pure medium without analyt and spiking.
If you want to determine the recovery of your analyte after bacterial transformation, it depends on youe experiment.
Alex
Thank you Tom and Alex.
I am actually trying to validate a method I have developed for the analysis of a compound secreted by bacteria. This method is going to be published (I hope!) but I don't have enough idea about the validation criteria. This is why I am worried about what method to use in the recovery measurements.
Thank you all for your help. :)
