Peak in Blank Injection-RS
Hi guys,
In the blank(diluent) injection,for RS method of a NCE molecule, am getting a peak exactly at a RT(about 24 min.) of main peak.
Diluent is ACN:Buffer=1:1,
Buffer here is CH3COONH4+dil. CH3COOH.
I have tried no. of expts to identify its origin.
viz. variations in system,column,chemicals but is not successful.
No matter what is done , this peak is somehow not affected and it appears same in all cases.(area is almost same )
Column is YMC Pack pro C-18(150*3 mm,5 µm),
UV is 230 nm
flow rate is 0.5 ml/min for the gradient elution
Time A B
0 70 30
27 10 90
35 10 90
37 70 30
45 70 30
MP(A)- BUFFER
MP(B)- ACN : MEOH+dil. CH3COOH= 600:400+2.5 ml
Any thoughts will be highly appreciated...![/quote]
Shrikant.
"variations in system,column,chemicals but is not successful. "
so,I am confused. Try to change diluent (ACN:Buffer=1:1)
to other rate (ACN:Buffer=1:2,1:3 etc) to see whether there will be any variation of blank peak, thus may be find the origin.
Shrikant,
Try to search the forum for contamination of the mobile phase A (contamination of the water used in the mobile phase). You'll find several threads about diagnosting ghost peaks due to the present contamination in the HPLC water.
Hope this helps
This one comes up often enough that I've posted a brief (about 15 minutes) mini-seminar on our web site:
http://www.lcresources.com/more_resourc ... hp?f=3&t=5
You will have to register (free) and log in to access it.
In total there are 14 users online :: 0 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 14 guests
