When we should use Normalization in GC
Dears,
When we should normalize Gas Chromatograph results?
Is it to compensate the change in results due to change in specific gravity etc of the measured component? Can we normalalize 50 pecent of a stream?
Hello
You generaly normalize samples when you detect all the components and you can calculate or measure Response Factor for each component, generaly done on gas samples. all other cases use External or Inter standard methods.
you can normalize to what % you want.
Good Luck
