total chrom
I am working on perkin elmer GC FID with total chrom software. I need to develope a method for TPH analysis using "timed group". Can any help me?
Timed group is an "on/off" function where you assign any peak within the window to a group ID, then they're calculated as a single peak using the sum of peak areas within the window (if memory serves correctly).
DR
DR
Thanks for the reply. I segregated the diesal range into two groups one >C10 to <C18 and second group is >C19 to <C29. and they were assigned in the time group wind but when run was done in the final report it is said that there is no group to be identified.
I run 1000ppm diesel standard.I am getting very good chromatogram. it seems i an going some work wrong inthe method.Can you pls tell in detail how to enter the time group in detail?
NJ
NJ
I can't (it has been several years since I used T*C now), but I suspect someone else can, or you could check the Users Group at the vendor's website. Forum for users with service plans
DR
DR
Sir
Many Thanks for the information.
Regards
NJ
Regards
NJ
