Supressing Cl ions from evaporating in HF
i am trying to quantify trace Cl in HF acid using an Ion Chromatography system. However when doing a recovery, i find that all the Cl ions is lost when i evaporated the HF acid.
Does anyone know of any chemical which i can add to prevent the loss of Cl ions while still eliminating the F ions which upset the accuracy of the chromatogram?
To where do you evaporate HF (are you really talking about hydrofluoric acid?).
These old ion assays, which are usually quite a bother for general chemistry students, might work. Don´t remember if a reaction of F- with AgNO3 was mentioned.
Yes when i mentioned HF i do mean Hydroflouric Acid.
I usually evaporate the HF in a fume chamber. The HF fumes are then sucked into the exhaust system and scrubbed by a scrubber before releasing into the atmosphere.
Just wonder how the HF is scrubbed. Maybe you can use that technique to get at the Cl-?
In total there are 16 users online :: 0 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 16 guests
