Exporting Chemstation Data
I just purchased a 7890 GC with Gerstel Autosampler. I'd like to be able to export data (sample name, vial, retention time and area) to an excel spreadsheet. This must be possible, can someone direct me either to an Agilent library or maybe walk me thru this?
Thanks much!
You should find something under File--> export file. Then you can choose the type of file you want , normally csv (comma-separated values) file type gives you the results in an excel sheet. But you have a help button that directs you to this specific topic when you're under export file-->csv format.
At_om
In total there are 24 users online :: 0 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 24 guests
