Increasing FID temperature
What typically happen when FID temp is increased? Do the responses increase or do the decreases?
Response will increase and so will the noise :wink: You need to optimise to get the maximum signal to noise ratio. In most cases your manufacturer will have recomended a temperature range, then where possible use 20C above the maximum programmed column temperature
In total there are 68 users online :: 2 registered, 0 hidden and 66 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 66 guests
