Result ID's
Does anyone know when you process a run, why the result ID's for the injections are in sequencial order but when they reach the standard injections, they tend to skip 3 result ID numbers?
Without more details (type of data system, layout of injection set etc.), I can't be certain but I would hazard a guess that it has something to do with the injection pattern not matching the data processing pattern (especially if you want samples calculated against an average response from all of the standards).
DR
In total there are 25 users online :: 1 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 24 guests
