empower
HI
With regards to empower - does anyone block users from reviewing results prior to prosessing results - is this common practice within other labs?
thanks
I can't imagine why someone would do that.
DR
thats seems a bit ridiclous..although i worked in QC in medical devices company and they did the same...........they barely allowed any acess for ordinary analysts
I suppose it's possible, but seems a recipie for headaches and unhappy chemists...I've never done this, though you'd have to have a look under "user type" privileges.
HI
thanks
Why would you want to?
If you've designed a half decent set of templates you can spot any chromatogram that's been reprocessed out of sequence anyway.
Either that or your managment doesnt trust the users to deal with the results correctly.
Good judgment comes from bad experience, and a lot of that comes from bad judgment.
