manual hplc??
it could be to run hplc without chemstation?
we have the isocratic bump and hplc column which are connected to icp-ms
so i'm thinking to use the column in separation then collecting the fraction and analysing them later by gc-ms or tlc
you can use agilent handheld controller if you think thats enough
http://www.chem.agilent.com/Library/use ... _ebook.pdf
"you can use agilent handheld controller ....for 1100 modules....if you think thats enough
http://www.chem.agilent.com/Library/use ... _ebook.pdf"
And 1050 modules can be run just from their front panels.
In total there are 22 users online :: 0 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 22 guests
