High Pressure because of 6 Port Valve
Dear Reader,
We have a shimadzu LC. Recently, our pump was showing a high pressure and we diagnosed it back to conclude that it is because of the autosampler unit.
So, can you please suugest a possible solution on how to go about reducing the pressure by adjusting the autosampler part of it.
Regards
Nausheel
Replace rotor seal, clean out that area as necessary. See if any of those tubes are clogged.
We've had this happen on "another vendor's" six port valve, that was a Rheodyne valve.
In total there are 32 users online :: 1 registered, 0 hidden and 31 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 31 guests
