Restore a polymeric RP column?
17 posts Page 2 of 2
if this was the case then it should continue to occur, right..?
Depends on how you test it.
Aside from that; did I get the the eluents and the gradient protocol right?
What is the theory behind the NaOH column regeneration? Can peptide bonds really be hydrolyzed at ambient temperature?
In total there are 34 users online :: 2 registered, 0 hidden and 32 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 32 guests
