Chromeleon/Dionex question
Does anyone know how to bring the PDA signal up on the screen just whilst the pump is on, so you can see it settled before starting a sequence run. At the moment, you can not observe any signal (a black line) until you have pressed start.
Cheers
The blue circle on the top bar, 3 positions over from the question mark. It toggles Acquisition On/Off. Then a pop-up appears asking what channels to aquire.
Hope that helps.
E
thanks, otherwise I would porbably use Status task bar with Acq On/Off button forever ;-)
In total there are 33 users online :: 0 registered, 0 hidden and 33 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 33 guests
