do i need a prep uv detector
i have a one inch column, which i want to run at 20ml/min. do i need a prep uv detector if i do not care about signal senstivity. anyway, what is the difference between prep and analytical uv detector?
I think you just need a prep flow cell. Shorter path length in the cell gives better range of absorbances, but less sensitivity. Check out this Waters article below:
http://www.waters.com/webassets/cms/lib ... /wpp20.pdf
In total there are 31 users online :: 3 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 28 guests
