inaccurate gradient baseline
gradient is not accurate. I put 0.1% acetone in methanol as B solvent, pure methanol as A solvent and run from 0% B to 100% B. baseline should be straight if gradient is accurate. however, my baseline fluctuates a lot as showing below. anyone knows reason?
Image[/img]
Read through this article by John Dolan and Jonathan Gilroy from LCGC. It should help you figure out what's going on with your pump, outside the on-board diagnostics and tests you may have in your instrument software.
http://chromatographyonline.findanalyti ... rticle.pdf
In total there are 32 users online :: 3 registered, 0 hidden and 29 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 29 guests
