What is w/w?..or w/w %?..what context can you use it in?
so how do i make a w/w solution? bascially i am writing validation protocol and i want to explain the make up of a solution....is it correct to write.... 100% solution is 50mg/100l w/w...is this correct?....or should i just write a 100% solution is 50mg/100ml?
I understand what w/v % is...i just want to understand the context in which w/w can be used.
% w/w is something you are more likely to see from your manufacturing folks. Labs are generally going to use a % v/v or a % w/v.
An example of w/w would be 1 gram of acid in 1 kg of water; something where you have a weight on both the part and the whole.
An example of v/v is 1 mL of acid in 1 L of water as you know volume amounts of both the part and the whole.
An example of w/v would be 5 g of potassium acetate dissolved in 1 L of water as you have a weight on the component and a volume on the whole. w/v is common in a lab for buffer preparations.
Hope this helps with the context in which all are used ... I am not so sure if it will.
Do you mean that you are preparing a standard solution at 50mg/100mL and you want to describe this solution as "100%" in the context that you will then prepare other dilutions from it?
If so, I would avoid stating it's 100% as this is potentially misleading, and instead describe it as a "concentrated standard" or some such neutral term, and then describe what dilutions to prepare from it.
Murphy's Law: If anything can go wrong, it will.
Method Development Corollary to Murphy's Law: No matter what you write, someone, somewhere will find a way to misinterpret it.
It is your job to make that misinterpretation as difficult as possible!
1. Minimize ambiguity by specifying the *exact* procedure for weighing/preparing/diluting the stadards
2. Specify exactly what they are (e.g., "dimethylchickenwire, 10 mg/mL)
Tom, ah, now would that be 10mg/mL of dimethyl chickenwire.3H2O potassium salt 99% based on 2.7% solvent from Sigma, or would it be 10mg.mL dimethyl chickenwire lithium salt, anhydrous 98% from Fluka?
You are absolutely right: particularly with mg/mL solutions, it is absolutely essential to state exactly what product you are using, as the weight of stuff in bottle per mole is likely to vary enormously.
In total there are 31 users online :: 3 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 28 guests
